MY04-05-06 clutch delay slave cylinder removal
Old 08-12-2005, 07:44 AM
  #111
kelvin96gsr's Avatar
I don't really sense the clutch delay when i'm shifting in releasing it into the next gear.
Rather I sense it when I push the clutch in it seems like it delays in disengaging
Old 08-12-2005, 10:55 AM
  #112
SIIK2NR's Avatar
Originally Posted by exceltoexcel,Aug 12 2005, 07:15 AM
Yeah but its a change from the norm, unless I'm pushing the car harder than I used to.
Make sure that you are completely off the clutch during shifts.... It's VERY easy to still be on it only slightly when feet and hands are moving so quickly... remember that the hands move faster than the feet. This can also be the problem with gear grinding.. I had to teach my son to slow his shifts way down before speeding them up. If your mechanics and timing are off....you will feel a delay every time...and eventually it WILL be the clutch....
Old 08-12-2005, 12:48 PM
  #113
exceltoexcel's Avatar
My foot is completely off the clutch for like 1/2 a second before the clutch engages. No way I'm on it. Oh yeah my feet are often quicker than my hands. I've been ocoming off the clutch before the shift a few times.
Old 08-12-2005, 01:26 PM
  #114
SIIK2NR's Avatar
I'm talking about being off the clutch before you GAS/THROTTLE.... If you gas/throttle before you are completely off the clutch then it will slip and regardless if your foot is off the clutch you will not catch gear until the delay is over or you let off the gas again.
Old 08-12-2005, 01:52 PM
  #115
Intrepid175's Avatar
[QUOTE=exceltoexcel,Aug 12 2005, 02:48 PM] Oh yeah my feet are often quicker than my hands.
Old 08-12-2005, 02:52 PM
  #116
Abide's Avatar
I managed to pull this out last week, spent prolly 2 hours on that stupid snap ring, finally got it and it was cake from there!
Old 08-13-2005, 03:37 PM
  #117
johnqt3's Avatar
ahhh... okl i need some help asap, i tried this mod today but after a few hrs i could not get out the snap ring... im tired and i dont want to try it anymore... so i go and put it all back and start doing the bleeding of the clutch and now my clutch wont stiffen up and i see some fluid leaking out of the boot where the slave cylinder goes into... what could be causing the leak? please help
Old 08-13-2005, 03:41 PM
  #118
It's the clutch first gear now
Old 08-13-2005, 03:53 PM
  #119
SIIK2NR's Avatar
You need to pull off the assembly and RE-SEAT into the joint. Your slave unit is not seated properly. If you have to you can remove the rubber housing to see what it is your trying to align with.
Replace the rubber housing and re-seat the slave. Bleed the clutch again and you will be fine.
Old 08-13-2005, 04:28 PM
  #120
johnqt3's Avatar
Thumbs down
well i stopped the clutch bleeder from bleeding and its full my now my car wont turn over... ahhh why is this happening. i did the bleeding correctly and a more then a few times making sure the resevoir was full at all times. my clutch seems loose at first too when i pump it but after pumping it a couple times it stiff where it should be... but i think when i let it rest a little and pump some more its light at first again and will get stiff after a couple pumps. can someone hep please... i need to get the car running again.
Quick Reply: MY04-05-06 clutch delay slave cylinder removal
