my s2k wont start
my s2k wont start
My 2006 S2k won't start or even crank, the dash doesn't turn on, I deployed for 7 months, before deploying I unplugged the positive side of the battery so my alarm wouldn't go off and drain the battery, now it won't start. After trying a new battery it still won't start. Any Ideas on what it could be, I left the car on empty before I left but I don't think it would be a gas problem cause the dash wont even start.
Im gathering you are getting no power what so ever to the car, so it has to be something to do with the battery or the terminals..check to make sure none of the fuses are blown..check them all..
No it was garaged for the deployment so I don't believe its wiring. I tried jumping it and still didn't start, so I bought a new battery and still didn't start. Speakeasy thanks for the advice ill try that and see if that's the problem.
ahh I thought you said everything turn on gauages etc, SO yeah check Fuses inside your car, your gonna have to look for fuses where your clutch pedal is right on top under dashboard, its hard to get to because of the seat.
good luck.
good luck.
S2000mikey
02-13-2013 06:40 AM
S2Kevinn
03-06-2012 06:01 PM
