my s2k wont go int gear
hi, my name is cesar and i am new hear, i got a 2000 S2000 that i just got, and i having problem geting it into gear, i had it for a bit, and it was hard some times to put it in gear, and now its almost imposible to go to any gear, i just install a new sleve silinder and its still acting the same, i bleed it and i just order a new cluch for it, i was wandering if it cod b something drferent that may b causing this, if anyone had this problem i will b thankfull for any info
I will check that and i havent. They dont have a dip stick on them so were can i check it. I miss my babe and i want to get it back on the road. If its ok do u have any other sugestions thanks
Here is a good place to look
https://www.s2ki.com/s2000/topic/548...d-maintenance/
but more specifically
https://www.s2ki.com/s2000/index.php...2&t=565855&st=
Check your clutch fluid reservoir, it's next to the brake fluid reservoir.
If it's empty and you're stranded use a straw to transfer fluid from your brake fluid to put in your clutch fluid reservoir. (use a clean straw ) you only need a bit.
You'll need to bleed it since it's sucked up air assuming it was empty.
It goes in when the car is off. And i bleed the cluch. Instal a new sleve silinder. And it still wont go. But if i put it in gear and start the car the cluch fells like it wants to ingaga but the gears wont grind and it does this in all gears including revers
You think so?
