my s2k wobble problem
i have just started noticin will iam drivin for example in 6th on the freeway when i disaccelerate my car has this funny wobbel ,its had to explain wen under acceleration the front end slightly lifts because of the torqe naturaly,wen i get of the accelerater it sit back down but has a wobbel ,wat could this be ?
I had the same problem when I replaced my rear tires and kept my Bridgestone originals on the front. Between gears, my car would wobble. Replacing the front shortly thereafter helped, but I'm sure it was the alignment and the fact that all of my tires (KUMHOs) have the same grip and bite. I'd check tire pressure first (cuz its easiest), but then alignment. Also, how's the tread on those tires?
I'm having the same problem ... it seems like (around 4,000rpms) my S starts doing this funny wobble, my rear tires need to be replaced - they are getting really bald... but I have a feeling its something else thats causing this problem.
Illiniwek
06-10-2007 07:44 AM
kuni
12-06-2003 01:19 AM
