MY s2000 engine has gone bad
1. What is the year model of the car? MY car is a 2002
2. How many miles does it have on it? 45xxx
3. No
4. Most of the time in driving normal, but theirs times when i drive it hard
5. No
6. i Just got my car 3 mnts ago
7. No
3. No
5. No
7. No
I would try http://www.haprecycling.com/
they are in Sacramento Ca I don't know where you are but they always have s2k's
Burnt valves, Burnt pistons Cracked block??
Sounds like a 100 dry shot poped her.
Entire Fuel system failed, and starved the motor of fuel, and the nitrous was engauged at WOT, and poped the motor.
Block just dont crack, being NA and being set on cruise control.
I bet some injectors failed, which i would get them tested. And there was too much oil in it and somehow cracked the block
I would def look into Hmotorsonline, I have bought a B16a2 and B18c5 from them- They were great!!
Did you get to see the tachometer just before the engine died? There's a chance that the oil was low.
Did you check your oil level often? Did you change your oil when you purchased the car? I bought my '02 S a year ago with similar mileage as yours and lucked out by checking the oil frequently (due to my obsessive nature) and realized that the S consumes a LOT of oil. Of course the issue was later resolved by doing some research on this board, etc, but had I not checked, my engine would've needed replacement.
mohammez
03-29-2017 10:40 PM
wadswoaj
06-03-2004 11:47 AM
