My S Feels Sluggish.
Old 06-10-2011, 10:09 AM
RedSunS2K's Avatar
Default My S Feels Sluggish.
On certain days my S2K feels kind of sluggish. I'm not sure how to explain but I'll try my best.
Here goes...
Once in a while the ride will be smooth. Throttle feels very responsive. It will feel like it has a little more torque as well with buttery smooth shifting. Feels great when launching.
Other days it just feels bogged down, less responsive and feels like I need to put more effort into shifting. Also launching feels like a total total let down.
What I've done so far:
Changed Oil and Oil Filter.
Changed spark plugs to OEM Laser Platinums.
Changed OEM air filter to K&N drop in.
Changed Transmission fluids.
Differential fluid.
Filled my tires to manufactures recommendation.
Re-greased shifter with UREA.
Never let my fuel tank never drops below half.
I'm changing my spark plug seals and valve cover gasket this weekend. Not sure if thats a problem as I noticed some oil on my spark plugs when I was changing them.
What else is there?
Old 06-10-2011, 10:14 AM
nofearofdanger's Avatar
Heat soak?
Old 06-10-2011, 10:15 AM
The S is ultra responsive to the temperature outside. On a hot day it will run noticeably slower than a cold day.
Old 06-10-2011, 10:19 AM
RedSunS2K's Avatar
I ruled this out only because I brought the in March and it was happening then. It was still pretty chilly out and snowing where I live.
deepbluejh's Avatar
I can also confirm this. My car feel significantly stronger when it's cool outside.
Old 06-10-2011, 10:21 AM
rob-2's Avatar
Upgrade to Ap2
Old 06-10-2011, 10:26 AM
Originally Posted by rob-2
Upgrade to Ap2
What
Have you tried a 'Map Whack?', seems to be the most prevalent culprit for intermittent engine behaviours.
The map sensor that is.
Old 06-10-2011, 10:36 AM
RedSunS2K's Avatar
Didn't know what you meant by map whack. I googled it and got this DIY.
http://forums.s2kca.com/showthread.php?t=19607
So basically I just unplug the harness and tap the sensor with a blunt object?
Give it a try tonight.
Quick Reply: My S Feels Sluggish.
