My low SC dyno...
Old 05-07-2001, 06:41 PM
Wesmaster's Avatar
Ok, it's not "terribly" low, but I want some advice. But first let's tackle the doubters.
First of all, the car runs like a champ - very, very fast, and I have been able to compare to stock s2000's. I am having no hesitations.
My dyno was sorta low, and it didn't push strong to the redline, gaining all the way like other dynos showed. I only have the SC as a mod, and I'm curious if the air/fuel needs to be tuned or what.
I emailed Comptech just now to see what they say.
Dyno:
Wesmaster
Old 05-07-2001, 09:23 PM
davepk's Avatar
Hi Wes... For comparison here is a Pic of my Dyno on a dyno Jet. I have since dynoed it on a chasis dyno @ Comptech with better results...
283HP @ 8800rpm & 174.4FtLbs @ 7600rpm. The AirFuel ratio as measured by an exhaust probe varied from about 11 to 12.
Both dynos were done using the Ghost Booster Rev0.1
I also have the ProFlow TB installed.
Here is the link so you can get a closer look...
http://albums.photopoint.com/j/ViewPhoto?u...&p=45757462&f=0
Old 05-09-2001, 07:49 AM
Pinky's Avatar
That P-Flow TB is definitly resulting in about 10 HP+! Hell it makes 6 on a NA tuned car. People would be supprised at the amount of power that just the TB makes in the mid range.
Old 05-09-2001, 03:37 PM
SteveUCI's Avatar
[QUOTE]Originally posted by Pinky
[B]That P-Flow TB is definitly resulting in about 10 HP+!
Old 05-09-2001, 04:28 PM
Pinky's Avatar
[QUOTE]Originally posted by SteveUCI
[B][QUOTE]Originally posted by Pinky
[b]That P-Flow TB is definitly resulting in about 10 HP+!
Old 05-19-2001, 04:13 PM
Wesmaster's Avatar
Update:
I had the car in the shop to have the new clutch installed and I had the installer check the belt, to see if it needed to be tightened (Comptech's suggestion). It turns out it was a little loose. They say this is common with a new belt. So you guys might want to have your belts checked.
Wesmaster
Old 05-19-2001, 05:39 PM
WRS2K's Avatar
Ask Comptech if the front grill would have any effect on your low dyno.
Old 05-20-2001, 06:05 AM
joe_s2k's Avatar
I wouldn't think so, since there is no airflow at the dyno. The car would be still and no air is being force in through the grill.
Old 05-20-2001, 08:08 AM
cjb80's Avatar
Are you going to dyno it again with a tighter belt? That should increase the boost quite a bit....
Edit: Does anyone know who makes the pulley on the back of the S/C?? Does Comptech fabricate it or did they buy it from someone else?? If so, what company?
Thanks
Old 05-20-2001, 12:11 PM
Wesmaster's Avatar
[QUOTE][B]Does Comptech fabricate it or did they buy it from someone else??
Quick Reply: My low SC dyno...
