my custom turbo set up
Old 07-26-2004, 01:36 PM
bigpurp's Avatar
Bigger injectors would not hurt (your duty cycle at WOT with the stockers is prolly not ideal at 7 psi), and some gauges (boost, fuel press, oil press, AFR) would be nice too.
Old 07-26-2004, 01:59 PM
S2KEvolution's Avatar
is your manifold tubular stainless steel or cast iron? if it's tubular does the manifold run and sit in front of the engine (in front of pulleys, like where the supercharger sits, or does it stay in front of the block?)
OTHER THINGS YOU NEED:
- oil filter relocation kit
- oil feed line
- oil return line
- vacuum lines
- gaskets
- tapped oil pan
- wastegate dump tube
OTHER THINGS YOU MIGHT DEFINITELY WANT TO THINK ABOUT:
- CLUTCH!!!! (stock clutch wasn't built to handle the 300 rwhp...)
- don't know if your running a stock exhaust or what, but larger piping would definitely help also.
- another thing that would HELP (not keep) your motor from blowing is a thicker headgasket to lower the compression. I heard there is a headgasket made for a new turbo setup coming out for our cars soon that lowers compression to 9:1, but that's a huge difference between the stock compression, so I don't know if thats true. Definitely a thicker head gasket though.
Old 07-26-2004, 02:00 PM
mustangkiller01's Avatar
i have the gauges... and figured that i would need the injectors.....if anyone else has anythign to add it would be appreciated.
Old 07-26-2004, 04:36 PM
kane.s2k's Avatar
you're in way over your head
Old 07-26-2004, 07:14 PM
why am i in way over my head???? i have the time and the proper funds to make this work so why the negitive feeling?
Old 07-26-2004, 07:17 PM
i have all the oil lines and vac lines and gaskets..... and planned on tapping the pan....i just bought the emange unit as well. clutch will be done over the winter cause i don't drive it any more after nov. and i only put about 300 miles every 2 months on the car anyway.
the manifold is cast iron and jet coated
Old 07-26-2004, 07:19 PM
and sits back behind the oil filter..
Old 07-26-2004, 07:42 PM
DigiSol's Avatar
Post
Some body just posted for sale some injectors that would work and an wide ban o2 sensor. just thought to tell you
Old 07-26-2004, 07:59 PM
but if you finish it and get it done right. then ill give you many many props. as long as its reliable
Old 07-26-2004, 09:11 PM
again....i have deep pockets and multiple other cars to drive while i work on this one..plus i'm patient.... if other members can do it i see no reason why i can't. i know my way around a car and know where to go when theres something i can't do... but i'm always looking for advise and direction.
Quick Reply: my custom turbo set up
