My crank pulley was tq'd on by GOD himself
#41
Originally Posted by S2Kage,Aug 12 2009, 02:09 PM
Just make sure you are using atleast 1/2inch drive so that there is no "Flex" in your breaker setup and soak that mother over night in penetrating fluid... every little bit will help ya.
Hondas may be known for it but this is the only honda that you cannot get an impact gun on it due to room... unless you want to take your rad and AC condenser out.
Originally Posted by MasterForce,Aug 12 2009, 03:49 PM
thats wierd. i sprayed some WD-40. then got a another person to help me remove it. he used a 3 ft cheater pipe to hold the crankshaft and i used a 5ft cheater pipe. thing came off after like 4 pulls. took me less that 15 minutes. same thing to put it back on.
#45
What you do, is spray so WD-40 and try tighten it little bit to loosen it up a bit and then try pushing it. I wouldn't pull on a extension bar. To bad you can't turn it vertical and then just hang on the bar with your friends.
#48
#49
Sponsor
Originally Posted by ikeyballz,Aug 9 2009, 12:20 AM
jump kick that sumb*tch. "shock" is better than slow motion...just make sure the damn thing is seated properly. better get, one guy hold it seated/put little pressure, other guy jump kicks. just make sure you hvae a bed or something for him to fall into (:
I dunno why, but a mental image of that made me lol.
__________________
AP1 and AP2 Clear Headlight Diffusers!!! - Clear out your S2000 headlights!
LED Conversions for all S2000 lights
Keyhole Covers - Get the Shaved look
Oil Drain Valve - Easiest Oil Change ever!
_________
For LEDs for your other cars, head to our new website: SupernovaLEDs.com. Same great quality, easy-to-use website. Pick your car, we'll show you what fits.
_________
#50
i had the exact same situation with my h22a motor.
after days of trying everything, this is how i ended up getting it:
i put on the solid (not ratcheting) short 2ft 1/2" drive breaker in a horizontal position, parralel with the ground.
held it in place carefully with left hand.
held huge maybe 20+lb brick in my right hand, smashed down on the breaker bar as hard as i can with brick.
TADA!
the motor was out of the car though...
TADA!
