My compression numbers
2003 w/133,000 miles. The first three cylinders were 210-215 , I did three times each cylinder. But the 4th cylinder was 220-235. So I'm wondering why is it like this? I used a brand new compression tester from Advance Auto parts and did not use the adapters that were included in the compression kit. Could that be why?? Thanks
It could be so many reasons (such as more oil sealing the rings in that cylinder or better valve seating), but those numbers are flat-out awesome for 133K miles
Compression in my 4th cyl was a little higher than the rest. On my 2003 s2k w/ 118k mi. compression numbers were 220-225s average for 1-3 and 230 for 4. I let the engine turn over 6 times per cyl.
yea I dynoed the car and made about 187whp and it was lower than what I was expecting. So someone suggested that I should do a compression test.
Originally Posted by Stratocaster' timestamp='1310479096' post='20770711
I would be happy with these numbers even on a newer motor. Have do a leak down test yet? Why are you looking at this at all, are you having an issue?
