is my Clutch dying?
Old 02-01-2011, 04:08 AM
Croc's Avatar
will do!!!
also will grease fork ends.
Old 02-06-2011, 11:47 AM
Croc's Avatar
back from the mechanics.
there was a "point" indeed at the slave cylinder push rod - i wasn;t expecting to see it at just 54,000km.
anyway - we grinded it, put some green urea grease on it and on a tip of fork's up jaw (we couldn't reach a tip of the lower one).
clutch pedal now is smooth as a butter - unbelievable !!!
but my problem didn't dissappear completely
clutch is not slipping.
but under load the pedal has this "notch" at initial press
any additional ideas where to look?
Old 02-09-2011, 08:37 AM
Croc's Avatar
maybe it has something to do with "clutch delay valve"?
Old 02-13-2011, 12:49 AM
Croc's Avatar
bump
Old 02-20-2011, 09:08 AM
Croc's Avatar
driving more now i understand that my clutch is sticky.
no leaks at master and slave cylinders.
it's stickyng only at high rpms shift.
i guess that thrust bearing should be regreased - but it doesn't make any sense to pull out transmission just for this.
any damage can be done driving lik this?
any other solution that i'm missing?
Old 02-20-2011, 09:26 AM
Mark355's Avatar
Just curious--why DOT4 and not 3?
Old 02-20-2011, 10:35 AM
Croc's Avatar
i don't see why not
Old 02-22-2011, 12:18 PM
Croc's Avatar
bump.
Old 02-22-2011, 12:30 PM
w00t692's Avatar
Originally Posted by Billman250,Feb 1 2011, 04:13 AM
Pull slave.
grind point off of pushrod.
grease and re-install.
+1
My car's clutch pedal would stick at the bottom and i fixed it by grinding that point off.
Old 02-22-2011, 09:00 PM
Croc's Avatar
you missed this in the thread - this was done already
clutch pedal still sticking at initial press at high rpms only
Quick Reply: is my Clutch dying?
