My car's running like a 2
Old 06-19-2001, 02:47 PM
CG
CG's Avatar
Default My car's running like a 2
I took my car out to show a friend this afternoon and the engine cuts out at full throttle. WTF? It drives fine at lower RPM's but under 3/4 to full throttle it starts missing and bogging bad at 5000 to 5500 rpm's. The oil level is perfect and it will not even reach VTEC speeds. I'm thinking a clogged injector or some kind of fuel starvation but I'm not sure.
Any ideas? I've already made an appointment to take the car in but thought someone here might have seen this problem in the past.
Many thanks.
Old 06-19-2001, 02:49 PM
cmnsnse's Avatar
was it warmed up?
Old 06-19-2001, 02:58 PM
CG
CG's Avatar
Originally posted by cmnsnse
was it warmed up?
Yeah, I drove it about 15 to 18 miles and it was still doing the same thing.
Old 06-19-2001, 03:02 PM
cmnsnse's Avatar
I would have noooo idea then - wait maybe a spark plug is loose - Im shooting in the dark here, but one of mine was. Made it Idle rough.
Old 06-19-2001, 03:20 PM
cdelena's Avatar
Sounds like it might be the MAP sensor. Mine was like that intermittently.
Old 06-19-2001, 03:28 PM
josh3io's Avatar
i agree w/ cdelena. try removing and reinserting your map sensor, they get loose sometimes it seems.
Old 06-19-2001, 07:30 PM
CG
CG's Avatar
Thanks Guys, I'll let you know the outcome.
Old 06-20-2001, 06:42 PM
CG
CG's Avatar
Honda believes the map sensor is bad and will be replacing it.
I hope that's the real problem.
Old 06-21-2001, 05:12 AM
joe_s2k's Avatar
CG,
I had the same problem after having driven 15-20 miles. I apparently realized that I hadn't VTEC'd on this drive and decided to "step on it". When I hit 7k, it felt like a hitting the rev limiter when the engine isn't warm. It was obviously warm, but the car didn't want to go past 7k RPM. I repeated this a few more times on the way to work.
After work, I then had the bogging/hesitation problem all the way to the dealership. I parked the car, talked to the Service Advisorr, and gave the technician a test drive. Of course, all the problems disappeared. They took my word for it and replaced the MAP sensor free of charge after speaking to the right Service Manager.
That was the only time that I hit the rev-limiter "wall" when the engine was warm, but it hasn't happened since. I hope that the replacement MAP sensor fixes your problem.
Old 06-21-2001, 07:01 PM
CG
CG's Avatar
Thanks Joe, that was the problem and I now have the car back.
Quick Reply: My car's running like a 2
