My Car Wont Reverse!
hey guys i need some help... heres the problem; i start the car, it shakes alil bit as if its idling really low. Then when i put it in reverse in attempts to back it out of my garage, it'll back up a tiny bit but it feels very restrictive as if the ebrake is engaged. Then when i put it in neutral, the car jerks forward as if its gonna stall im totally lost here... if you guys can pls help me out with what u think the potential problem could be, id really appreciate it.
i didnt really try to go forward cause theres not much more room in my garage.. as far as getting into gear, it feels pretty much the same and the mileage on the car is only about 23000..
Has the car been sitting in the garage for a while? If the car is parked with the emergency brake engaged, especially after the car has been wet, the brake pads can stick to the rotors. The easiest solution for this problem is to back out of the garage with a little more throttle that normal. You will hear a loud bang that might even scare you, but that's the brake pads releasing from the rotor.
I'm not sure if the two problems are related as I don't have an explanation that combines low, erratic idle with the car being stuck.
well when i get off work, ill try again and hopefully it'll be a-ok but the thing that leads me to believe that something is wrong, is the car jerking when its in neutral.. but thanks for ur help guys i really appreciate it
