My car slides into 2nd with out clutch engagement
My second gear is shot pretty much. I want to know what will be cheaper to replace the 2nd gear synchro and 4th gear synchro(it grinds) or trans completely?
I've been driving the car skipping gears because I dont have 1500 bucks for a trans until next week.
I have heard more people have issues with rebuilt s2k transmissions than not. It's not quite as simple as just 'replacing the syncro' either.
Regardless, I'd suggest looking for a used transmission. I've seen a few posts about some reliable sources for vey reasonable prices, under 2k for AP1's and not much higher for AP2's. Perhaps it is a good time to upgrade if you have an AP1 transmission.
you've been here 1 day and you say "prob one of the hardest driven S2000 on this forum" ? that's a bit off the wall don't you think? Do you track your car? Do you race it at the drag strip?
as for your problem, i suggest you find a used tranny. most don't know how to do a good rebuild of the tranny, and it can cost you just as much in parts to do as to find a used one and swap that in.
AP2 tranny in an AP1. Would this simulate close to a 4.57 ratio in the rear?
It's a simple ratio thought but I just can't seem to think this out clearly. Maybe it's too early in the AM.. Do you multiply the FD ratio with diff or add? I can't remember.
I need to do some synchros next year and I'm thinking of just finding a used AP2 instead if I can benefit from the different ratio.
I thought it was higher as well. Unless the calculator is wrong?
http://www.turnzero.com/technical_resource...gear_calculator
Change the 04 FD to 1.16
Unless I'm doing something wrong it's the same as changing the 00-03 AR to 4.12
