My car sits lower on the passenger side
I've been hitting potholes at streets of willow which is known to bend your rims. one day I went to westend and then the owner told me he can't get more than -1 camber on the passenger side. He told me either upper control arm, lower control arm, or knuckle is bent. but he couldn't really tell which one is bent. couple weeks ago i found out that both front and rear of the passenger side of my car is lower than the driver side. front was about half finger gap lower and rear was full finger gap lower.
which part do you guys think i bent?
suspension part of my car is 100% stock btw
I had that problem for a year. I replaced the rear subframe, lower contorl arm on that side, both shocks. No good.
Turns out it was frame damage. A frame guy did fix it, got it aligned close to spec, not perfect. But it's ok now, doesn't pull to the side or anything.
the thing is my friend noticed my car lower on passenger side when i was driving, alone. and im pretty heavy.....220lbs
imma check out rubber spring spacers tomorrow and if it is not that, then could it be lower control arm?
saving4one
08-15-2014 11:05 AM
OVER 9000!
05-28-2013 08:11 PM
tru
Member S2000 Classifieds and For Sale
04-14-2004 12:39 AM
