My car needs to be jump started more often?
Have you checked for a current draw on the battery when the car is shut off? May be you have an electrical problem that is draining it. I had a problem a few years back with a bad power antenna that did not shut off when the car was off. Rewired it to shut off with the ignition and problem solved.
Batteries should last much longer than 3 years.
ok, problem fixed, needed a new battery. Was an '03 battery and needed more higher crank amps since I have a sound system, and a few other things compared to how my car was when I got it 3 years ago.
Originally Posted by AP1FTW00,Feb 25 2008, 09:25 AM
How would you check to see if there is a draw? Volt meter?
SimbaDogg
06-04-2019 03:48 PM
geesquared
11-11-2015 02:22 AM
