Is my cam timing dead on
looking at it in person it looks good to me but figured I would double check
just did the ap2 retainer swap and a valve adjustment to .008" intake and 0.10" exhaust
not too familiar with the f20c so figured I would just snap a quick pic and check with everyone
The timing marks line up good, but I don't know if I'm seeing the punch mark on the sprocket properly. The punch mark dot on the sprocket is supposed to be in the middle of the two coloured pieces of the timing chain. Maybe you can confirm that it is as I may not be seeing the picture correctly, it looks to be off one tooth to me though and the chain may need to be moved one tooth to the right on the sprocket. If the mark is centered between the two coloured pieces of the chain then disregard my comment.
Crank is dead on the tdc mark down below thank you all for the help to double check put the valve cover back on and it fired right up and runs quieter then ever I think this was the first adjustment in 60k
hey there i have a quick question ... i had to redo my 3mm headgasket last month .. had to shave off 20,000 off the head .. we put the motor back together with the same size head gasket .. AEM ecu e85 .. 1100 cc injectors etc .. the car did get hot before that ..but no cracks or anything .. now the car idels perfect .. but when i step on it or try to drive it i have no power and it sputters and back fires ... any idea ? I m kinda helpless right now .. any advice would help.. could it be timing ? MAP sensor ? ... do i need a new tune after the 20,000 shaved off the head ? help plz
thanks
TangoVTEC
03-23-2014 09:32 AM
Sebring Silvur
12-10-2003 03:35 PM
