My A/C is Going CRAZY
My A/C went out last friday, just quit blowint Cold air. But it was still blowing air. So I called Honda on Monday and made an appointment for Tuesday morning to have them look at it. About an hour a after I made the appointment with honda it just started blowing cold again. So Weird! then it worked for another day or so and then quit blowing cold again. But now I have noticed that when it isn't working if I throw it in low gear while driving to get the RPM's up it will blow cold again. So I am thinking it might be some kind of heat sensor or something like that. Please Help!!!
I've seen several cars at the dealership do exactly this.Sometimes its a low charge (leaking condenser).I've also seen the thermostat on the evaporator unit malfunction causing an ac shutdown.Have you ever had the ac serviced before?If so it is also possible that the system has been overcharged.
