Is my alternator dead?
Old 12-01-2010, 03:03 PM
  #21
ArinX's Avatar
awesome, il do that test later today.
thanks
Old 12-26-2010, 09:40 AM
  #22
S2KennyT's Avatar
I'm having similar symptoms and my car wont start now
before... (when my car was running) my dash-lights would flicker at idle
yesterday I started my car up and the EPS light was flickering like crazy
so I turned the car off right after, and it hasn't started since
-unplugged and took the battery to be tested at Autozone, and it was bad
-installed new battery and same result
Car doesn't even crank over
Dash-lights don't even come up when I turn key all the way to on
Old 12-26-2010, 11:12 AM
  #23
WarrenW's Avatar
I had an issue earlier in the year and I wasn't sure if it was the battery or the alternator. Turns out it was the battery and the alternator output was fine but in the precess I did a test of the alternator and here is what I had. Hope this helps
Battery
before start up (all power off): 12.67V (dips to ~9.5V when starter is engaged).
With car on:
No electrical load:
At idle: 13.39V
At 3k RPM: 14.41V
Lights only on:
At idle: 14.26 initially then up to 14.32
At 3k RPM: 14.37
A/C only on:
At idle: ~13.5 initially then up to 14.19
At 3k RPM: 14.20
Both Lights and A/C on:
At idle: 14.02
At 3k RPM: 14.12
Turned power off and battery voltage started dropping into the 13's.
Old 12-28-2010, 10:26 PM
  #24
ronnuke's Avatar
Sounds like you need a new diode pack for your alternator. I had similar symptoms with the flickering dash lights and weakening battery until I replaced my diode pack on my alternator, I replaced the brushes too for good measure. HTH
By the way the alternator passed the Autozone test too with bad diodes. Don't trust their test for our alternators.
Old 12-29-2010, 04:30 AM
  #25
slalom44's Avatar
Where did you buy your diodes and brushes? Is this something that Honda sells? Did you replace the bearings while you had your alternater pulled apart?
Old 12-30-2010, 02:12 PM
  #26
ronnuke's Avatar
I got mine here:
http://www.hondaautomotiveparts.com/auto/j...TOR+%28DENSO%29
Parts number 3 and 8
Old 12-30-2010, 04:53 PM
  #27
Hirevs2k's Avatar
Originally Posted by adrian27,Dec 1 2010, 05:28 AM
which is the best car?Thanks
best thread jacker here. had me crackin up pretty good too lol
s2Y00
11-17-2017 12:21 PM
Ziggyzacks2k
03-21-2015 02:15 PM
9kFever
04-26-2010 09:36 AM
scottieboy561
03-22-2009 11:35 AM
s2000
01-18-2004 07:52 PM
Quick Reply: Is my alternator dead?
