My Air Bag Light just came on!
Old 05-29-2015, 04:33 PM
S2KERRP2's Avatar
Default My Air Bag Light just came on!
I just randomly started my car after playing some basketball and looked down and it was on... idk why.... it drives and everything is normal.
I Reset the ECU and did a relearn but didn't do anything please help?
Old 05-30-2015, 08:44 AM
Billman250's Avatar
Received 1,395 Likes on 836 Posts
ECU is not linked to airbag.
It will need to be written out with a paperclip, and then see if it re-codes.
It cannot be cleared via battery disconnect.
Yellow connector with 2 green wires in the under-dash fuse block, look up the procedure to reset.
Old 06-12-2015, 03:51 PM
S2KERRP2's Avatar
ok I did the procedure and it was gone for a couple hours while driving and came back on.
I don't want this to set me back couple hundreds of dollars im just sick of looking at the light is there anything I can do??
Old 06-12-2015, 06:08 PM
bgoetz's Avatar
My guess is the passenger seat sensor, but just a guess. Do you put bags and other things on the passenger seat?
Old 06-13-2015, 06:07 AM
Billman250's Avatar
Retrieve the code, that is your next step.
Old 06-13-2015, 08:38 AM
superchargedk20's Avatar
Keep resetting it. I had the same issue in my rsx. It took a couple of days of resetting but eventually it never came back on
Old 06-13-2015, 09:10 AM
S2KERRP2's Avatar
Ok ill just keep resetting it, ill pull the code as well. I asked Honda but that was a mistake 120 just to diagnose screw that its just a light lol
I just don't wanna look at it anymore
Old 06-13-2015, 10:13 AM
Billman250's Avatar
I think its possible to get blink codes on this one (no scanner/dealer)
Old 06-13-2015, 02:09 PM
Did ur car seats get wet? I had my windows in my rsx open and it rained. That's what caused my srs light. I tried for days and it just kept popping on. Then 1 day the reset finally worked
Old 06-16-2015, 11:08 AM
S2KERRP2's Avatar
Okay I reset it again and no light so far it stays on a bit longer when I start the car but then just goes away. I don't recall them getting wet but it could be my shorts when I leave the gym from the steam room haha... well its good for now if it pops on again imma just reset it.
Quick Reply: My Air Bag Light just came on!
