My AC/Heater Doesnt Blow Air
Im having a problem with my air blower system, i dont think my blower relay is activating. I just put in a new relay fuse and it still doesnt work, but im not sure i got the right one, but if you guys know what could be the problem please let me know. is the fuse located under the dash? or under the hood. or would i have to change the blower motor perhaps?
Are you on fresh air when you are driving fast. That can be why you feel alittle air. Make sure you have power at the blue/white wire and ground at the blue/black wire at the blower connector. If you have that then you prob have a bad blower motor. If you have only power on both sides you most likely need a blower transistor.
If you have no power at all, a bad fuse or relay.
I second bad relay. Pull the blower motor off - its easy from the passenger side, IIRC its one plug and three screws.
Check motor with alligator clips and wire + 12V battery...
if motor spins, I almost guarantee its the relay...
