MX2000 dyno
Originally Posted by JFUSION,Oct 31 2009, 12:46 AM
well I initially thought it was a mechanical system changing at 5200 rpms as it looks like someone flicked a switch at that rpm, sometimes if you have a big cam swtiching over too early it will kill power like that and then pick up at a higher rpm. But i f you have a stock pcm, stock cams, stock cam timing, and stock vtec engagement point on this dyno run, then I would suspect the header design, where you get a bad resonance in the system and it messes with the power over a certain rpm range. My other suggestion would be a poorly designed intake system, but I think it is more likely to be your header. You refer to it simply as a shorty header, any other information on it ?. I've seen this exact effect before when we installed a high rpm intake manifold and high rpm header on a b-series engine, it just messed with the airflow over a certain rpm range and then it picked up in the higher rpms.
It might be the mods, but it looks like your AFR is all out of whack to me. Most factory S2Ks can get a damn near perfect line all the way through the dashed portion until the very end.
Originally Posted by hondaphreak,Oct 31 2009, 11:24 AM
the vafc doesnt mess with the fuel at all. it only tricks the ecu into sending more or less are to lean it out or make it richer. depending on what the tuner sets it at. plus vafc can allow you to set vtec as low as 4000 rpms in increments of 100 rpms.
And sure, you can set the transition to 4000 rpm, even 3000 rpm if you'd like, it'll just run like crap and loose a ton of power below about 5500 rpm. From what I've read on the boards, only people running an AEM EMS or similar, which can adjust both fuel and ignition, can realize any gains from setting the VTEC transition below 5500 rpm or so.
Originally Posted by Elistan,Oct 31 2009, 07:05 AM
The profile of the red trace is 100% normal for an S2000, albeit slightly lower on the peak end. My initial thought is that the odd shape of the blue trace is an artifact of the dyno itself, not something going on with your engine.
The blue dip isn't noticeable when driving, but I'm used to cars that are quite a bit faster than this one. I'm not entirely sure I could feel it unless I was trying to notice it.
A pic of the exhaust manifold:
The intake is a ram-air box in the driver's side headlight:
The length of the intake from the start of the TB to the end of the pipe is 14.5". I don't know what the optimal length is here.
The car looks quite a bit different now than it did in the above pics, but the intake and exhaust are the same. I can't decide if I should adopt my Megan header to fit this chassis, or build a 4->1 header. I'm also considering permanently putting the car into VTec since I don't really have any need for low-end. From what I'm reading you really need something that will tune timing too, like an AEM or an E-Manage.
BTW, the car ran 13.8 @ 102 with me hitting the rev limiter twice (the tach had stopped working so I was having to base my shifts off of my PerformanceBox's MPH readout).
Do you have your Dynojet run files? If you send them to me, I can put them on a chart with some other S2000 runs with nearly the same torque, but more hp, so you can see where you're winning and loosing.
header sucks and while your at it get an aem ems and get that tuned. vafc will not be worth it in the long run for you.
no need to mill/build head for 230whp. can do that with stand alone and CAI/header/exhaust.
its all in the tune, well that and a way better header design that that bastard child you have on there.
Here:
https://www.s2ki.com/forums/index.php?showtopic=417646
Guy on here already did this. Helped him a little bit and he made decent power.
