MULDERIZED AP1 HEADLIGHT
#121
Originally Posted by daktruckie99,Oct 26 2007, 08:57 AM
I can't imagine these headlights fitting in a toaster oven lol. It took up almost my entire oven and it's full size.
#122
Originally Posted by daktruckie99,Oct 25 2007, 11:32 AM
You can do it anywhere you want but here's why I won't recommend it. The strip left open when doing it the way we have all done is right above the bulbs. This still allows for the light to shine through at a safe quantity.
Moving the strip over to the side will decrease the amount of light substantially to the point I would be worried about the safety (and legality) of someone not being able to see your blinker when activated.
#123
Plus I did various photoshops and it just looked kinda odd. If there is too much blank space it makes the headlights look just as awkward as the factory did.
#124
hey everone, has anyone had foging issues yet? i did a set of 00 si lights and about four months later they turned.. and yes i did reseal them before i was done, anyways let me know i really like the look i may do it to may suzuka ap1
#125
#126
Originally Posted by AP1_S2k,Oct 26 2007, 12:54 PM
...I made sure I got a good amount of silicone on the area where the plastics meet...As long as you get a good amount of silicone on the lights and give them a final bake once everything is back together you will be fine.
By strict interpretation of what AP1_S2k wrote, the only difference I'd say I've done is that I don't put the bead of added silicone in-between the 2 halves, but rather I bake the 2 halves back together...then I add a final bead of silicone where the 2 halves joined. That said, I'd also point out that in the few instances where I've opened a set of headlamps and the existing sealant seemed excessively dry, *there* I would follow AP1_S2k's thoughts and I'd add a bead of silicone right in the 'crevass' along the black half of the headlamp...then squish the two halves together...then bake...then add final 'seam bead'. Make sense?
- Dave
#127
Originally Posted by AP1_S2k,Oct 26 2007, 09:54 AM
II had issues the first time I opened mine up but the second time around I made sure I got a good amount of silicone on the area where the plastics meet and I have driving in the rain for about three days straight with no issues. As long as you get a good amount of silicone on the lights and give them a final bake once everything is back together you will be fine.
#128
#129
Originally Posted by daktruckie99,Oct 26 2007, 07:39 PM
No problems. I am like a month in and have had some pretty damn awful weather. My smoked sides have leaked but no headlights
#130
Originally Posted by my00b16si,Oct 26 2007, 07:39 PM
that may be it i didnt bake it after i sealed it, i may just have to do this then, thanks man
