Mugen Installation Report -Part 1- (long with many pics!)
#21
Do you still have the OEM exhaust ?
How much hp do you expect with this set-up ?
I know that when you change the thermostat and the fan switch it makes the engine run cooler, but does it increase hp ?
Is it realy necessary to change the radiator cap ?
Thanks
Thanks
#22
Salaska, great job on the car! You will definitely feel the header along with your other mods. Would love to hear about your Mugen ECU when you put that on later.
I just installed the Mugen exhaust yesterday and LOVE the sound. It's just right! It has a deep sound but not loud.
The Mugen header just by itself was a great mod! I look forward to adding the thermostat, switch and cap later, without the coolant shower of course.
#23
camerons2000: have u ever took your car and seen what it runs at the QM?
t.c.: Do you still have the OEM exhaust ?
t.c.: How much hp do you expect with this set-up ?
t.c.: I know that when you change the thermostat and the fan switch it makes the engine run cooler, but does it increase hp ?
t.c.: Is it realy necessary to change the radiator cap ?
#26
Do all cars in Germany have that 4th light under the license plate? Is it another brake light?
I think the radiator cap will be necessary. The cooler switch and thermostat don't increase cooling capacity. They just make it start working sooner. The higher pressure radiator cap does actually improve cooling capacity (by some amount), which is necessary to reduce the normal operating temperature of the coolant. There is a lot of debate about whether the OEM radiator can really keep the coolant cooler, even with the high pressure radiator cap.
#27
gernby: Do all cars in Germany have that 4th light under the license plate? Is it another brake light?
#28
I am asking myself this question : This engine ( like any engine ) is design to run at certain temp. because of the thermal ( dilatation ) ( not sure of the term ) isn't it bad to run it cooler ?
I mean i never see more than 3 bar on the temperature even when i am on the traffic at 90 degrees or if i push the car hardly for an extended time.
