Mugen Header vs Stock results on Dynapack dyno
Old 06-03-2003, 03:14 PM
  #41
damcgee's Avatar
UL, how much do you charge for a dyno... also, how much woudl you charge, to say, tune a V-AFC?
Old 06-03-2003, 04:32 PM
  #42
ultimate lurker's Avatar
A baseline is $75. VAFC tuning is a flat $150 fee. Other tuning (engine management systems) is $125/hr.
The gear selection should make virtually no difference on a Dynapack. Provided the correct gear ratio is entered into the system and the load time is kept the same, the only change will be due to the small changes in efficiencies between various gears. These usually amount to less than 1%. I've done back to back tests on the same car in 3rd and 4th gear (keeping coolant and intakes temps the same). The results were within a couple hp.
UL
archtop
10-23-2006 05:47 PM
jsdude
09-20-2006 05:42 PM
s2kv
02-13-2006 10:26 PM
Arfiman1
04-30-2005 09:59 PM
12gage
08-11-2001 10:34 PM
Quick Reply: Mugen Header vs Stock results on Dynapack dyno
