Is the Mugen ECU open loop
Old 08-10-2005, 02:29 AM
Xd
Xd's Avatar
Default Is the Mugen ECU open loop
I know it doesn't adjust the timing from the knock sensor, just after knowing if this ECU can be pulled back to compensate for normal road driving.
Can the knock sensor be brought into the loop or is it that stripped down it will not compensate for any conditions?
Old 08-10-2005, 05:46 AM
Sideways's Avatar
The knock sensor is "cut." It is not available to the user.
Old 08-10-2005, 05:53 AM
Xd
Xd's Avatar
Thanks,
I noticed the O2 is cut as well, what are the other three Shipley?
Old 08-10-2005, 06:09 AM
Sideways's Avatar
[QUOTE=Tango
Old 08-10-2005, 08:04 AM
Xd
Xd's Avatar
Thanks Sideways, shipleys me having a blonde moment
Old 08-10-2005, 08:35 AM
cdelena's Avatar
Originally Posted by Sideways,Aug 10 2005, 08:09 AM
I'm not sure what Shipley means? Are you referring to Wordwork?
Speed Limiter = cut
Rev Limiter = 9000 rpm
O2 Feedback = cut
Knock Control = cut
Air Pump = Cut
Air Con(ditioner) = Cut
VTEC = no change
MAP = no change
Wonder what the Air Cond cut means.. it's operation is unchanged.
Old 08-10-2005, 09:19 AM
maxrev's Avatar
[QUOTE=Sideways,Aug 10 2005, 06:09 AM]
Old 08-10-2005, 10:01 AM
Xd
Xd's Avatar
Originally Posted by maxrev,Aug 10 2005, 05:19 PM
* Do not use this ECU on a street car as it will overheat the catalytic converter.
Oh!!!
DONE AROUND A 100 MILES ON THIS CAT
Old 08-10-2005, 10:10 AM
Amuse Boy's Avatar
whoops!!!
Old 08-10-2005, 10:16 AM
Sideways's Avatar
I put several thousand miles on my cat with no difficulties. It may cause problems if you run it very hard for extended periods.
I changed the original post re fuel map. I knew it was leaner from the dyno but I copied the data from an old post without editing. Sorry for the confusion.
Quick Reply: Is the Mugen ECU open loop
