MPH doubled?
MPH doubled?
Yesterday I'd started her up (like normal), took her out of the garage and went on my way when I'd looked down at the cluster and it says 50mph when I'm doing less than 30mph . After noticing that, I'd made a U turn and headed home and shut her off. Let it sit for about 30 or so minutes and started it back up again, back out of the driveway and put it in 1st so I can go back into the garage so I can check on the mph reading. It's saying I'm doing 30 when I'm actually doing less than 5mph, what's going on?
After messing around under the hood (touching wires, tighting sensors, etc) and started it back up, took her around the block and it was normal. What could cause this? Is there anything I can do to prevent this from happening again? HELP???
That's what I'd thought too but I'd looked at the speedometer and it's on MPH, I did click it back and forth just to make sure my eyes weren't playing tricks on me.
Originally Posted by xviper,Aug 23 2006, 09:00 AM
Do you have a speed compensator on? Yellow Box? Yellow Jacket?
Maybe your clutster is having a brain fart and is converting over to KPH but not changing the actual designation.
Originally Posted by Reds2kracer,Aug 23 2006, 11:05 AM
Nope, no yellow box. If it does have a "brain fart" then what can I do to prevent this?
This wasn't the first time it did that, same thing happened when I'd first took the S out from storing it due to winter but I'll surely do what you'd recommended.
Haven't seen a single mice for a few years now, can mice climb jackstands? Might be the wiring cuz I do have the Frog harness which is a plug 'n play harness for the VAFC, maybe it got loose?
