Mouse Wire Was Cut [photo]
Howdy,
Ive been getting a P0118 code as was going to order a new sensor and when I looked under the hood, I noticed this wire was eaten through or cut. Does this have anything to deal with the coolant temperature sensor it or is it something different?
https://drive.google.com/file/d/0B7d...ew?usp=sharing <- in case the embed image didn't work.
Thanks!
Thanks!
here is the coolant temperature sensor
the picture you posted is the vtec solenoid. that wire definitely needs to be reattached but im not sure how or if that would correlate with your code. i'll let someone else chime in there.
Two completely different things.
The cut wire is to the vtec solenoid, so with out it, the motor will not have vtec engaged.
The code point to wether a bad connection on the temp sensor or bad temp sensor.
Received 1,753 Likes
You also need to do something about the vermin. More wires will be chewed through, perhaps a nest will be found in the air intake. They can cause serious damage.
Thanks guys!
Yea i found 3 more wires that were chewed through!! UHG.
I can't find the nest. My intake was replaced out to a K&N kit. I'll have to get it on a lift and keep searching.
I'll try the mothballs, lemon spray and set a whole bunch of traps with peanut butter to get rid of them.
I'm open to all suggestions as he did quite a good amount of damage this winter. Gotta get rid of them somehow.
Thanks guys!
Put traps in the garage and under the car too. Once you get the current culprits, it usually takes a while for new ones to show up, and that's usually in cold weather.
Febreze is good for the urine smell in carpet and you can squirt it into the inside air intake to draw it through the HVAC.
I live in the country, and I don't drive the car every day. Sometimes not for a couple weeks. I've had field mice chew though, then get inside the hood liner, and like you have lost wires. Stripped all the "felt" insulation from my trunk above the fuel tank and the front bulkhead to build nests. Only glue and a few threads remain. Nests were in the truck tool tray, behind the trunk lining, and in HVAC. They went through the console from trunk to dash, which is where where the wires were cut. Both seatbelt sensor wires to the airbag controller, hand brake indicator on dash and another wire not used on my car.
Did you know that the S2000 has a tiny pet door just right for mice? There is a perfectly sized passage into the trunk with a rubber flap over it. I assume it's part of positive ventilation system. In the back wall of the truck, behind the liner. Comes out under the rear bumper cover, left of license plate.
Our other cars have been hit too. On my wife's Miata we had to disassemble the dash vents to vacuum out all of the nest material. My pickup gets hit more often. It sits under a carport rather than garage. Lost the entire hood liner for example, twice. Nests in center console and in the storage bins behind the back seats dash and of course hvac. Chewed part way through both rear seat belts inside the boots around the reels.
Traps all the time is all I can suggest. And don't slack off when you get rid of the current crop. Easy to forget. Get the first one before the family can move in.
I know you're joking, but there is no good time for outdoor (domestic) cats, assuming you mean roaming free. Especially true if you are running a habitat restoration project. google search
But a cat confined in the garage, even just at night, would probably work.
From Time article:
The authors discovered that the majority of kills could be attributed to ownerless cats, including barn cats, strays and feral colonies. The research showed that the animals largely prey on non-native mice and rats in densely populated urban areas, while in rural areas they target mice, shrews, voles, squirrels and even rabbits.
From Time article:
