Morning engine light
this morning i woke up and turn on the car. The Check Engine light came on. so i quickly turned the engine off and pop the hood to see whats goin on. Found 2 smalls hoes that was disconnected from the breather line. Must have gotten disconnected from doin a intake cleaning and changing the air filter. so i reset the ECU and turn on the engine again and the Light went off. But last night i drove it after i did the cleaning and no lights but this morning lights.
OK, there's a OBD plug under passenger side dash, short pins 4 and 9 with a paperclip, and turn on ignition. Your CEL will give you a 2 digit code for reference, by flashing. they are general codes that are not as specific as the standard OBDII codes.
Originally Posted by AeroS2000,Oct 16 2008, 01:56 PM
Found 2 smalls hoes
You should still take it to auto zone and have the OBDII scanner hooked up to see if it stored a code.
GaryB
05-11-2009 11:39 AM
