Mods while motor is taken apart?
Old 11-02-2006, 10:08 AM
Sponsor
Vendor - Starter Primary
JS2k.com's Avatar
Default Mods while motor is taken apart?
Only one I could think of was new gaskets so cooling is more efficient. CAI is easy even with the motor in..
Can you think of anything else? Cams maybe? but then that would require tuning right?
__________________
AP1 and AP2 Clear Headlight Diffusers!!! - Clear out your S2000 headlights!
LED Conversions for all S2000 lights
Keyhole Covers - Get the Shaved look
Oil Drain Valve - Easiest Oil Change ever!
_________
For LEDs for your other cars, head to our new website: SupernovaLEDs.com. Same great quality, easy-to-use website. Pick your car, we'll show you what fits.
Old 11-02-2006, 10:57 AM
clawhammer's Avatar
High compression pistons, thinner headgasket
Old 11-02-2006, 04:32 PM
Sponsor
JS2k.com's Avatar
Who makes a headgasket for the S?
I know that Hondata makes one for the RSX err I mean an intake manifold gasket
__________________
_________
Old 11-02-2006, 04:38 PM
Former Sponsor
jwkim's Avatar
I remember Spoon makes thinner gasket which raises 0.2 in CR.
Old 11-02-2006, 04:48 PM
EG-B18cR's Avatar
cams are a waste of money
Old 11-02-2006, 06:10 PM
clawhammer's Avatar
Yeah...
And the S2000's engine is already maxed out from the factory
Cams can make some decent power, especially if you bump up the horsepower.
Old 11-02-2006, 06:13 PM
CarbonS2000's Avatar
Build for FI!!!!!
Old 11-02-2006, 06:32 PM
GOS2K007's Avatar
You could go head gasket, valve springs, and retainers.
Old 11-06-2006, 10:25 AM
^AnDre^'s Avatar
What valve springs and retainers would you use?
what about valves? standard size, or oversized?
crower cams stage 3 or skunk2 pro+2?
I am moving to J's JDM pistons...
Iam in the same boat but I am also picking up a aem ems and looking at some good dyno time to get all the things worked out
Old 11-06-2006, 10:33 AM
JackS's Avatar
If the S allows, rebore ,resleeved and larger pistons.
Quick Reply: Mods while motor is taken apart?
