Mobil 1 oil filter help please...
i did a search concerning non oem filters and found some good feedback on the mobil 1 filters. i went out and bought the mobil 1 (M1-105) now without removing my stock filter yet, it looked like the mobil filter was too wide. so i went to the dealer to compare the openings of both filters and the mobil filter was in fact wider. how will it fit? i know that the mobil 1 is supposed to be an oversized filter but i thougt it would be taller not wider. i still want a mobil 1 filter but can someone tell me what model to get? is there more than one kind of m1-105 or something? please help asap my car is way overdue for an oil change.
MIke
MIke
you are doing the oil change yourself, right? just pop the hood and see how it will appear to fit. even if it is oversized, you should be able to tell if its going to fit.
The Mobil1 M1-105 does fit just fine. You can remove and insall from above, if you wish. It does have a slightly larger oil capacity, so you'll wind up using 6 quarts of oil.
Ted
Ted
Originally posted by Tedster
Wrench? Kung-fu grip, baby!
Actually, if someone finds a filter wrench that works well on the non-faceted M-105, let me know.
The MI-105 is oversized (wider diameter), but fits up with the oil filter boss fine and can be installed from the top. Meaning that the sealing 'O' ring mates up with the engine mounting surface and the threads are the same as stock.
The MI-104 filter is the stock replacement oil filter for S2000's and is what I'm using now. Several board members have had the MI-105 "loosen" up to the point of losing oil. https://www.s2ki.com/forums/showthread.php?...ighlight=MI-105 This happened to me at the track with the MI-105, so I'm done with that and am now using the MI-104 with no problems, yet!
I just tighten the filter by hand ~ 1 turn after the 'O' ring contacts the filter boss. Some guys suggest using rubber gloves or wrapping the filter with sandpaper for additional torque when tightening. No wrench needed, except when removing, sometimes. And then I use one of those plier type wrenches. Don't use this for installing because they have a tendency to dent the filter casing if you're not careful.
There was also some info out there that Honda uses the smaller filter on S2000's so that oil pressure was maintained during hard maneuvers. Don't know if that's true or not, just know that it is something that I read on the board, may be pure speculation.
Originally posted by DJ Qube
Maybe I need to work out more...
The thing is, an oil filter is not like a drain plug. The oil filter's rubber ring (if you oil it before putting it on the car) will expand over time and with engine heat. It naturally gets tighter.
