Mobil 1 Extended Performance
I recently saw the Mobil 1 Extended Performance for sale at WalMart. I have read about the normal Mobil 1 SuperSyn and the relatively new Racing variety as well. However, does anyone know how the Extended Performance version stacks up? Is anyone aware of any VOA or actual wear tests?
Here's an excerpt from the Mobil website explaining the difference between the Extended Performance and their regular Mobil 1:
"Mobil 1 Extended Performance motor oil is designed for today's longer service intervals. Mobil 1 Extended Performance products contain 50 percent more SuperSyn, 37 percent more cleaning agents, and 36 percent more anti-wear additives than Mobil 1. Mobil 1 Extended Performance with the Advanced SuperSyn System helps keep engines running like new and helps extend engine life by reducing wear and oil breakdown."
The URL was: http://www.mobiloil.com/USA-English/MotorO...nce_10W-30.aspx
- Jeremy (jnn4v)
- Jeremy (jnn4v)
Seems the search is kinda working. Some of these had few responses. Most likely because the other threads existed and people just had enough of the same topic.
https://www.s2ki.com/forums/index.ph...pic=273646&hl=
https://www.s2ki.com/forums/index.php?showt...270987&hl=mobil
https://www.s2ki.com/forums/index.php?showt...268482&hl=mobil
https://www.s2ki.com/forums/index.ph...pic=265438&hl=
CrAzYNeSs
10-04-2005 10:42 AM
