Mobil 1 = higher idle
Old 10-31-2010, 04:43 AM
  #21
fatjoe10's Avatar
Respectfully, not sure what's more pathetic, the question, or some of the answers given.
Mobil1 is a fine oil. I don't understand the paranoia about it being a bad oil, or the fact that it blows up chain tensioners.... now one's supposed to reset the ECU after changing oil with it? I've run M1 for most of the car's life, and nearly at 100k my tensioner and everything else is running strong.. what's the deal?
Credibility on this site is going down fast.
Old 10-31-2010, 05:24 AM
  #22
PWRMKR's Avatar
It's just allot of different people posting allot of different questions and allot of different answers.
No reason to be
Old 11-01-2010, 07:40 AM
  #23
kimimila's Avatar
Your car is normal - worry about something else. Let me give you something more to worry about. Mobil 1 changed their formula a few years ago, and after a big court case with Valvoline, were allowed to re-write the specifications for "Synthetic Oil" so Mobil 1 could be listed as a true "Synthetic". I used Mobil 1 for many years, but not after they altered their formula.
Old 11-01-2010, 08:27 AM
  #24
JackS's Avatar
I use Mobil-1 and have confidence in it. It has been my choice in the several Vette's I've owned in the past and remains my choice in my current S and for that matter, any car I may own in the future.
If I didn't feel this way and harbored any doubts, I'd switch to something else. There is no reason for anyone to accept any product as the best including Mobil-1. There are many other fine synthetics to choose from ,all very capable and worthy of your consideration as the "go-to" lubrication for your car.
Old 11-01-2010, 09:08 AM
  #25
SgtB's Avatar
Originally Posted by Bror Jace,Oct 30 2010, 04:07 PM
SgtB, I (and the original poster) were thinking it was the other side of the coin ... a thicker oil, or one with poorer cold-flow properties, would be a heavier drag on the motor and prevent the engine from reaching its target idle speed.
I sort of see your point, but the motor could hit 2krpm no problem even if it had gear oil in it. The IACV will adjust to let air in, and the ecu will add fuel to bump the rpm's up and match it's 2000 rpm target. You have to consider how minute the differences in viscosity are between engine oils of the same weight.
Old 11-01-2010, 09:17 AM
  #26
vtec9's Avatar
2k idle in the cold is totally Normal.
Been running Mobil1 and Penzoil Platinum for 124k miles with daily trips to 9k. Still on my first tensioner and my engine hasn't bloweded up.
Old 11-01-2010, 09:22 AM
  #27
ertbll's Avatar
Originally Posted by 13darkknight,Oct 29 2010, 09:31 AM
I thk mobil1 is fine lol. For $36, it has to b something good lol
Wow 36 dollars man go to wallie world(aka walmart). And gt. A five quart jug for abiut 25 dollars hahah i do this all the time and.i know then dollars save isnt a big deal bt it is when u saving up for other stuff!!!i
Old 11-02-2010, 02:53 AM
  #28
ZonaS2K's Avatar
I run Mobil 1 10-30 and every morning when I start my car it idles at 2kish. I always wait till the temp bar get 2 full bars then go on my way. By the time I get out of my neighborhood its fully warmed up. Perfectly normal, no worries bud....
Old 11-02-2010, 05:14 AM
  #29
vtec9's Avatar
^^ wasting gas
Old 11-02-2010, 05:48 AM
  #30
s2kohoh's Avatar
Mobile 1 ftw!
Quick Reply: Mobil 1 = higher idle
