Missing parts?
I think i do but it doesnt light up because when the key is swithed to key positon ll, it doesnt light up..
I plugged in the obd scanner it pulled three codes P1457
P0336
P0420
P1457
Whats the purpose of the air pump??
And will it do any damage if its open like in the picture or should i get the delete kit..?
P0336
P0420
P1457
Me personally, I would move those electrical connectors up into the engine bay and hide them behind the headlight.
Sounds like someone took the CEL bulb out. I'd replace that bulb and get an IZZE Air Pump Delete module or buy my air pump.
You're fine w/o the air pump but you want that CEL to work so it doen't hide a more serious issue.
You can remove the EGR valve at the back of the engine too. Previous owner didn't go as far as he could have w/ the removal of parts.
The Air Pump gets the catalytic converter up to operating temperature more quickly than w/o it, that's all.
Look for something like this down by your ECU:
Izzy kit eliminates p410 and 0411 for air pump. You have a few more issues like cat code and evap leak. Doesn't seem bad, I, d get the light working first. Dont buy the izzy kit just yet.....
Marloon
06-03-2014 08:17 AM
Marloon
06-19-2013 07:13 PM
S~Factor
35
06-13-2012 11:08 AM
