Missing bad at higher RPMs
Originally Posted by Morris,May 21 2007, 12:16 PM
No CEL has lit. Don't know where to look for codes, but would there be codes if the CEL never lit?
However, if it is a misfire issue, you'll most definitely get a code. There's probably something in the UTH FAQ about pulling codes & what they mean, too.
Thanks to everyone that offered suggestions. I pulled the cables on the MAP sensor, called it a couple names, plugged it back in and put a zip tie around it. Just got back from a test run and not a single hiccup. Running stronger than I have felt it in a long time. My hat is off to all of you. Live long and prosper.
chillout18
08-23-2010 11:36 AM
