Miss Fire
Well..im gonna assume you don't speak English well but being from Canada, im a bit surprised. Anyway, first find out what cylinder the misfire is in, then swap out the coil packs to see of those are the issue..
How long has it been since your valves were adjusted? If the air/fuel mixture is not under the correct pressure (compression) it will not ignite, do you smell fuel out the exhaust? Good luck
RobEvo5
12-28-2010 11:09 AM
