Mishimoto 2 Row or X-Line 3 Row
Gonna upgrade my radiator in the next couple of weeks and I found a new X-Line for $270 something. Now I dont know much about radiators so should I stick with the 2 row or are there any benifits of the 3 row over 2. Im not tracking the car anything just a DD until I find me a replacement DD.
Well awhile back car kept running hot like to the MAX! Even when I did put coolant in. Now its in a decent state it sits a 8bars on the gauge. But I do have 2 CEL lights for the cooling system both mention coolant levels or T-Stat issue. Dont remember the codes as its been months now but I figure if im going to change the T-Stat might as well throw in some extra cash for a new rad.
If its just a DD and you don't track/etc then upgrading is a waste of money.
Assuming you aren't boosted
Most likely you overheated because of air in the system or a leak somewhere. If it went to "max" you may have damaged the motor
Spend your money repairing your vehicle vs throwing aftermarket parts at it. Hopefully it's as simple as a t-stat.
The temp no longer goes to max I stated "a while back". Also I know the radiator was not the issue. The only issue I have is my T-Stat which is being replaced. The radiator replacement is purely for cosmetic purposes as the I dislike the look of the OE radiator.
I just wanted to know what difference between 2 and 3 row were.
From the manufacturer's website: " Each new X-Line radiator application has 3 rows for a core that is 25% larger than standard radiator applications"
They also don't provide heat transfer efficiency measurements, so the benefits going with a 3-row core are unknown. As your purchase is merely cosmetics, get whichever is cheaper.
Yea was wishing someone knew cause I wanted to compare the specs. But thanks for the input/help
Let us know if we can answer any additional questions! Good luck with the thermostat install and coolant system refresh!
Thanks
-John
