misfire running very rich
hey everyone.
my friends 2000 s2k is running very rich and the plugs are black. they are a month old. the check engine is blinking and the the car idles like crap. any ideas?
mine was running very rich, I decided to change out tbe primary 02 sensor, I don't have any scientific proof but it seems to be running less rich now judging by my rear bumper and exhaust tips.
You might have a bad fuel pressure regulator but you'd have to do a fuel pressure check on it to know that.
You should get the cel codes read, they could give you some insight.
I just had a similar problem actually n I thought it was the map. Check engine came on last night so I took it to Honda and it turned outto be the air pump. I would get it checked out.
how old are the plugs ?. Misfires are typically bad plugs, bad injectors, or bad coil packs, it is odd that it is on all 4 cylinders though unless something caused all 4 plugs to foul by running rich.
JDMilanoEG
10-09-2007 08:35 AM
