Misfire only at idle when fully warmed up.
I had the same problem a few weeks ago, it ended up being the coil packs so I bought 4 new ones from majestic honda website, 214 for all 4. My car would bog down when I would floor it and drive crappy and misfire under 3k rpm, but above 3k it drove normal.
Had this issue and it threw a CEL of the same codes
I did new plugs and a valve adjustment and the CEL went away. It still idles a little wonky now and then but it seems to have smoothed out.
Good luck!
Good luck!
![](https://staticssl.ibsrv.net/autocomm/Content/S2Ki/milestonestars-10yr.png)
If it is injectors you should tell me! I'm going through a whole list of things and man it's getting pricey...
That's not true at all
My friends car misfired. It was the valves all being too tight. Valve adjustment did it
I unplugged each injector at idle and the car stumbled regardless of which was pulled.
That's why I did the adjustment first and it went away
![](https://staticssl.ibsrv.net/autocomm/Content/S2Ki/milestonestars-5yr.png)
Just get the valve adjustment and let them take a look at everything else. I did that with mine when I had a misfire in cylinder #4 and it saved my engine from being destroyed. That's just a worse case scenario though. Good luck, but better to be safe rather than sorry.
