Misfire only on cold start and low rpm
Had a CEL light yesterday for cylinder 2 misfire and replaced the coil, drove it for a bit and the CEL light is finally gone and the car ran great, no loss of power or anything weird. Realized today when I start up the car on a cold start there is a slight misfire sound coming from the exhaust, the car only has a VERY VERY TINY misfire that has little to no effect on the driving. This slight misfire only happens in low rpm but after the car is warm the misfire is gone. As I said before I had a very bad misfire and the CEL was on but replacing the coil helped a lot but the sound of it being inconsistent coming from my exhaust worries me.
Gives me like a “phub phub phub………. phub…….. phub…….” sound
Did my very first compression test myself where I rented the tool from my local o’reilly (LOL SORRY) and came with the numbers of Compression TEST
C1: 180
C2: 170
C3: 180
C4: 180
Compression TEST 2:
C1: 190
C2: 170
C3: 180
C4: 170
I cranked it like 8 times so after the second test my battery began to give me bad readings. Any recommendations, very stressed!
C1: 180
C2: 170
C3: 180
C4: 180
Compression TEST 2:
C1: 190
C2: 170
C3: 180
C4: 170
Compression:
Nominal: 228psi
Minimum: 135psi
Max variation: 28psi
What engine and how many miles on it? Fuel? "Mods?"
-- Chuck
Nominal: 228psi
Minimum: 135psi
-- Chuck
Your compression is right at the average of Nominal and Minimum (well above minimum) and the differences are in tolerance. What makes you suspect compression?
(Your auto-correct changed your Invidia exhaust to a NVIDIA PC video card? Mine tried it too just now.
-- Chuck
-- Chuck
spectacle
06-30-2008 04:39 PM
