Misfire/flashing CEL
#51
I dont get your car at all. how can you have so many new problems arise.
P0118 is for the coolant temp sensor.
Do you have a scan tool that can read data? If not, get one.
#52
Just started my car at work and it did NOT want to start. Had to give gas and it started eventually but very hesitantly. I don't have a scanner that reads data I just got it ran at auto zone. Seemed like when I started it it was almost like it was flooded or something.
#53
first things first.
Get every code, work through them one at a time till the CEL is off and monitors are complete.
Dont do anything else, or concern yourself with any hard starting, flooding nothing.
Sounds like you have a compromised wire harness. If the engine was not removed and installed with care, damage or pinching of the harness will result....but never mind that right now.
go buy a scanner that reads datastream. if you can buy an S2000, you can buy a scanner.
Plug it in and read the coolant temp when cold.
#58
Lol. Forgot my wallet at work had to go back to get it. Turned car off about 3 minutes or so came back out started right up. Now have a steady 3 bars, running like a champ. I don't get it?!?!
#60
Problem lies within my wiring harness. Idk why im so stupid, but after I parked in my garage, with 0 bars again after being warm, I popped my hood wiggled one of the harnesses and bam 3 bars not running vs 0 bars not running when I shut it off. Guess I need to rip this bitch apart.
I say I'm stupid bc I should have tried this a lot earlier.
