misfire cylinder 4.
misfire cylinder 4.
I have a 2000 s2000. Ran it low on gas. 2 days later i park after a drive i hear the engine different starts shaking. And CEL starts flashing i check it cylinder 4 misfire. I also have a CEL for TPS and for canister. Any ideas what it could be? Ill be running a compression test tmrw and will get new spark plugs and check the coil packs. The car used to jerk occasionally at cruising speed. But never had CEL.
Swap injector/coil/plugs with a good cylinder to see if you can isolate the fault to one component (assuming it is bad). e.g. see if the misfire follows the cylinder or the part.
Otherwise do a valve adjustment, compression test and leakdown test for further investigation.
I have switched out injectors that was for sure not the problem. Cylinder 4 was still bad. I will switch coil packs tmrw and im doing all brand new spark plugs anyways. It needs it. What if car has no compression?
chicomacattack
01-28-2015 04:37 PM
