Misfire at 8-9000rpm
Old 12-26-2010, 07:57 AM
davidc1's Avatar
Originally Posted by JFUSION,Dec 26 2010, 08:36 AM
oil consumption issues can cause that misfire as well, and consumption likely is worse at those rpms.
Even if the plugs looked clean?
Old 12-26-2010, 07:59 AM
davidc1's Avatar
Originally Posted by DocS2000,Dec 26 2010, 08:47 AM
If you have a perfect idle warm and cold, the plugs look good and the stumbling happens only at 8+, its almost certainly a fueling issue. I would replace the fuel filter (good maintainance) before looking into the injector cycle.
Start simple and I hope you'll be able to isloate the problem.
On one of the forums, someone just posted a great DIY on replacing the fuel filter.
Wouldn't it be less expensive though to put the car on a scope to check the ignition system first?
Old 12-26-2010, 08:23 AM
DocS2000's Avatar
You certainly could do that. The fuel filter is quite inexpensive and often overlooked. I'm sure your on the original one and you've got an 03. It may be time anyway.
But absolutely, scope away.
Old 12-26-2010, 08:48 AM
flyingtoaster's Avatar
When the valve adjustment fixed my intermittent misfire, I would misfire at idle, on cold and warm starts, with no throttle.
Old 12-26-2010, 10:31 AM
rob-2's Avatar
Can you like us to this filter DIY thread?
Old 12-26-2010, 01:18 PM
Carbon Blue's Avatar
you really shouldnt gap iridiums due to the sensitive tip on the electrode that can break off. good luck
Old 12-26-2010, 08:41 PM
davidc1's Avatar
Sure, this is the link to the DIY for the fuel filter.
http://s2000.com/forums/engine-tech-drivet...html#post153901
Old 12-26-2010, 08:44 PM
davidc1's Avatar
But you have to gap the plug. It isn't always set correctly for your car from the manufacturer of the plug. Plus, when you gap them, you don't touch the electrode.
Old 12-26-2010, 08:47 PM
zeroptzero's Avatar
Received 3,798 Likes on 2,676 Posts
so were you getting CEL's on the misfire ?, if so what cylinder were the CEL's leading to ?. Once you determine the cylinders affected start by swapping the coil packs between cylinders and see if the CEL's change along with the coil swaps to identify if a problem exists with the coils. You can do the same with the injectors. Most misfires occur due to coil packs, injectors, and plugs.
If you weren't getting CEL's then I don't think it was a misfire as they detect the very slightest misfires. Could you be feeling clutch slippage as opposed to misfiring ?.
Old 12-26-2010, 09:23 PM
davidc1's Avatar
Unfortunately no to both questions. As I stated in my post, no CEL's. And the misfire occurs with the gearbox in neutral and just revving the engine. Intermittent as well.
It was proposed that it could be a fuel starvation problem and I should change the fuel filter, but it puzzles me that it's intermittent and in neutral. I would think that the amount of fuel being pumped is far less at 8000rpm in neutral that when in gear at wide open throttle at 8000rpm.
Quick Reply: Misfire at 8-9000rpm
