Mini-Cat? Which CEL fix actually works on a 2006+?
I keep hearing of CEL fixes not actually fixing anything on 06+. Then I found this. . . http://www.bigdaddiesgarage.com/mini-cat-cel-fix.html
What do you guys think?
At this point I'm not to worried about price as long as it actually corrects the issue. I don't feel like spending 5bucks, 10min of my time, and a drive to auto zone for nothing.
Or should I just go with the "might-work" blox first? http://www.kingmotorsports.com/p-136...liminator.aspx
Thanks!
Thanks!
I used 2 spark plug anti foulers on my 06 work fine for 4 years now. You can get them at your local auto parts store. Google "s2000 anti foule" you should fine instruction online.
99sh is right. I ran a test pipe on my06 for a long time with the antifoulers in various configurations and only had mixed success. The computer is a lot more sensitive than the earlier models and is very hard to fool. My suggestion is to get a flashpro. You'll realize way more gains from that test pipe and you can just turn the sensor off.
Did the fouler (hope that's spelled right)fix after work today and it fixed it. . . for about 20miles. I guess its good to know my ECU is no fool, ugh. Just did a bit of reading on flashpro and wow, I'm pretty much sold. That's probably the route I will be going. Thanks
