Metal sheen in engine oil
Old 04-04-2018, 05:32 AM
windhund116's Avatar
Received 1,529 Likes on 1,033 Posts
In, for lab results.
What kinda oil consumption did your engine have?
Old 04-04-2018, 06:00 AM
bgoetz's Avatar
I don’t think it is anything to worry about. I looked at one of my changes in the sunlight and it looked like metallic flake paint. The resulting oil sample was fine.
Old 04-04-2018, 06:04 AM
kraquepype's Avatar
I'm not entirely sure as I've only had the car for a month, but I've been adding some here and there. My guess would be about a quart between oil changes. I'll know more once I get some more miles on this oil.
Old 04-09-2018, 08:45 AM
kraquepype's Avatar
I've ordered some UOA kits for the next oil change. Trash got picked up before I could dig out the old filter
Did some work, had to replace valve cover gasket and adjust the valves, I also took off the vtec solenoid and looked there. I didn't see a speck of metal in any of the ports or filter on the gasket. Exhaust valves were a little tight but not by much.
Didn't see any material laying around the head either, so hopefully I'm in the clear. I do see some slight scoring on a few of the cam lobes, not sure if that is normal.
Old 04-09-2018, 09:20 AM
starchland's Avatar
Where is the vtec solenoid filter
Old 04-09-2018, 10:22 AM
kraquepype's Avatar
Forgot to attach it, heres a pic of the mesh.
Old 04-10-2018, 01:06 AM
starchland's Avatar
Old 04-10-2018, 01:36 PM
rrounds's Avatar
Looks good and clean.
ROD
Old 04-11-2018, 10:53 AM
Soviet's Avatar
Camshaft wear doesn't look too unusual to me.
Old 05-01-2018, 02:01 AM
SpitfireS's Avatar
The exhaust cams between tower 5 / 4 and 4 / 3 and intake cams between 4 / 3 show a line on the non-vtec lobes.
It's also on the corresponding cam rollers, as far as the image shows.
That could be raised (cracked) retainers, make sure they are ok.
I don't think it would be the cause of metal in the oil though.
Quick Reply: Metal sheen in engine oil
