Metal on metal grinding?
So as of yesterday, I'm hearing a metal on metal grinding noise coming from the front passenger side wheel well. I sounds like it's only happening when there's load on the tire/spring.
It's hard to explain exactly how it sounds, but thing a piece of metal spinning on a lathe and you touch something else metal to it. There's no marring on the rotors though and my brake pads are probably at 20-25%
may be your wheel bearing / hub.
but im not sure.
try jacking the car up in the front and moving the tire/rim back and forth and around and see if there is any play, if there is... could be your wheel bearing/hub
but im not sure.
but im not sure.
but im not sure.
mambo
10-21-2015 02:40 PM
