Metal lumps in oil pan - non magnetic
#23
I'm almost wondering if these are just casting abnormalities with the block that eventually worked themselves loose? I know on a couple occasions when I've been building one of these engines I've found some "slag" hanging off a part of the block that I could break loose with my hand, although it was never anything this chunky or thick.
#24
These being the shape that they are, look like they have been rolling around in the oil pan for a long time. They didn't start out looking this way, where ever they came from. I tend to agree with the poster above, possibly even the oil pan itself?
#25
Looks like the T-1000 terminator found his way in your oil pan.
I would peak up around the piston skirt area the base of the cylinder walls and see if anything looks off in that area. Also check the rod end caps and connecting rods.
#27
#28
We looked up the bottom and didn't see anything abnormal. But we are not 100% sure.
#29
Thanks for all the advice and suggestions guys. Really appreciate it.
It seems that the only way to find out what went wrong is to strip apart the engine.
So now I have two choices.
1) Let the engine run as it is and when it fails, get a used engine.
2) Strip the engine and while its all opened up might as well do the CNC speedshop F24 conversion.
What do you guys suggest. Especially any experience with the CNC F24 kit is highly appreciated.
Once again, I really appreciate all the advice and suggestions. Thanks
#30
I'd run the usual engine tests, keep an eye on the spark plug conditions, and check oil usage. If all is ok, let sleeping dogs lie.
Looking at the debris, it seems there is some brass objects mixed in with the aluminum blobs. Thin, stamped things. Like part of an electric connection. You never dropped something like this into the oil filler cap, by accident, any time in the past? Maybe, the previous owner?
Good luck with the engine!
