Metal flakes in my used oil after oil change
Old 05-26-2009, 08:26 PM
Olegator's Avatar
Time to freshen up the engine!
Old 05-27-2009, 05:58 AM
black2000's Avatar
So now there is a distinct smell while sitting at idling and not moving.
I don't know what that means...
I can't post pics of flakes right now because I am between computers at home. and I don't have an approriate tool for slicing my used oil filter in half either (aside from a hacksaw). But I am getting the general message about bearings. I would love to freshen up with a stroker kit or something but it just aint the time...
I am not planning on having my new school loan the rest of my life so most of what I do now is el cheapo (i don't mean crap parts just not turbos or ultimate tuning packages)
Old 05-27-2009, 09:19 AM
SpitfireS's Avatar
Did you actually see the metallic oil?
Any missfire CEL's?
Oil light?
IMO, a street driven Sk2 should not have worn crankshaft bearings at 141k miles AT ALL!
Not even on dino oil.
Old 05-27-2009, 12:18 PM
slalom44's Avatar
I'm not sure how clean your oil drain pan was, but if you had a Used Oil Analysis done on that old oil (even without the visible metal particles) you would know what your problem is.
Old 05-27-2009, 12:28 PM
PureSportsDriver's Avatar
Originally Posted by black2000,May 26 2009, 08:06 PM
This is probably the way I will go. I would like to do it myself. I will just try and order the bearings through the Honda dealer unless anyone knows of a better alternative as far as these parts.
Look into ACL bearings.
Old 05-27-2009, 04:30 PM
black2000's Avatar
Only those copper/bonzish flakes in the oil, no other of the signs for bearings that people have mentioned. The oil itself does not seem to have metalic look either
There is this weird smell tho when idling
I think I'll try that analysis tho, i have never actually had that done before
Old 05-27-2009, 04:31 PM
black2000's Avatar
I'll have a look
Old 05-27-2009, 04:39 PM
bgoetz's Avatar
Originally Posted by AeroS2000,May 26 2009, 11:17 PM
if your car is running fine, dont worry about it. your just wasting money.
If the bearings are infact wearing (which it sounds like there is a good chance there may be) that statement could not be further from the truth.
If he changes them out now then he is looking at a minimal investment in $ and a little bit of work. If he waits, the next thing that will happen is he will get engine knock, and now he will know for sure he has a bad bearing. The only problem is that by the time there is a knock everything is most likely stretched and he will need to completely rebuilt or replace the bottom end.
Old 05-27-2009, 04:41 PM
bgoetz's Avatar
hey if you know how to do it right, then more power to ya . Just make sure you check and recheck everything.
rworne
03-04-2007 11:53 AM
ihavenosn16
10-01-2006 12:25 PM
LubedKoala
06-11-2005 10:09 PM
FormerH22a4
03-08-2003 04:22 PM
Quick Reply: Metal flakes in my used oil after oil change
