Metal dislodge sound.
I have an ap1 with an SOS stage 1 supercharger. I got the car back after a couple of years of a friend holding on to it. It seemed a bit neglected.
So to the point, I heard some strange engine noises and narrowed it down somewhat. I remove the supercharger belt and the serpentine belt.
I start the car and let it idle till warm than when I rev the vehicle while parked, it sounds like a piece of metal dislodges and bounces around before resettling. It will settle down and then I rev it high again and it seems to dislodge again and bounce around for a bit before it settles.
Unfortunately, this sounds like it could be very bad. I have attached an image of where the sound might be coming from. If anyone has any ideas or thoughts please let me know
potential noise area
Last edited by monst; 12-30-2022 at 10:22 AM. Reason: unsure if that is the exact noise area.
Ever lose an oil filler cap?
No. Sometimes the cap falls back behind the engine and gets stuck. Rattling against metal parts.
Are you running a catalytic converter, it might have some loose bricks within it if you are .
May wanna check starter motor bolts as your under there,maybe a loose bolt
