megan racing cat delete gone bad!
Old 03-05-2006, 09:51 AM
mic_crispy's Avatar
Default megan racing cat delete gone bad!
the other day i heard an extremely loud rattling under my car.. checked it out, and couldn
Old 03-05-2006, 12:12 PM
villain2000's Avatar
That sucks. I just ordered one! I honestly cant see how it could be fixed without tearing it apart. Not worth the time or trouble.
Old 03-05-2006, 03:15 PM
i2ichal2d's Avatar
what exactly happen to the test pipe?
Old 03-05-2006, 04:40 PM
S2kracka's Avatar
How can we tell you if its fixable if you don't tell us whats wrong?
Broken welds? Resonator falling apart on the inside? Your penis stuck in the 02 bung?
Old 03-05-2006, 04:42 PM
mic_crispy's Avatar
nope it looks perfect. i can see straight through it. its in the resonator somewhere....thought i made that clear..no need to be rude.
sucks for me.. guess ill be buying a new one.
Old 03-05-2006, 04:45 PM
S2kracka's Avatar
I was just kidding around, no need to be upset
I'm sure if you send it back to Megan they'll give you a replacement or weld in a new resonator for you. Maybe you could contact them and they'll sent you a new resonator you could have welded in at any shop to avoid down-time.
Old 03-05-2006, 07:22 PM
Emil St-Hilaire's Avatar
If it's a penis sticking problem,try using K.Y.!!!
Old 03-05-2006, 07:31 PM
S2kracka's Avatar
KY is water based so it will break down in high-temps, Vasoline would be better for this application!
Old 03-06-2006, 09:51 AM
S2000GT's Avatar
i dont have a megan but do you have to use the mechanical 02 sensor mod with this? I used it with my T1R and it worked its way loose after about 1000miles.
i thought my exhaust was screwed too.
Cranked it down with some loctite and its been ok ever since
Old 03-06-2006, 10:09 AM
mic_crispy's Avatar
yeah I had to use some non-foulers? however you spell it. so I wouldn't throw a cel but it wasn't that rattling. I have the test pipe off now and all I have to do is shake it alittle and it starts rattling. something inside the resonator.
Quick Reply: megan racing cat delete gone bad!
